You can configure an existing resource by clicking an entry in the table. This displays the following dialog, allowing you to configure the resource:
Display name - the resource name as it is displayed in the table
Client ID - the unique string used by the resource to programmatically identify itself to FME Server
Application category IDs start with app_. Component category IDs start with transformer_, format_ or ext_. Service category IDs start with service_.
Category - a drop-down list used to specify the category of the resource
Roles - allows roles to be assigned to and removed from the resource
Roles in the left column have not been assigned to the resource. Roles in the right column have been assigned to the resource.
To assign roles to the resource, select the roles in the left column and click Add. To remove roles from the resource, select the roles in the right column and click Remove. To assign or remove all roles to/from the resource, click Add All or Remove All.
